How to apply Qt creator application to iMX6Q Wayland backend?
1,205 次查看
seanhsu
Hi all:
I have implemented a Qt5 application program that is successfully cross compiled into a program that can be run on iMX6Q x11 backend. Now I want to run the same program in Wayland backend, but got the following error message.
This application failed to start because it could not find or load the Qt platform plugin "xcb".
Available platform plugins are: eglfs, minimal, minimalegl, offscreen, wayland-egl, wayland.
Reinstalling the application may fix this problem.
Aborted
Does anybody know how to fix this problem? Or is it even possible to develop a program using Qt creator for Wayland? If not, what develop program should I use for Wayland backend? Thanks for replying.
Sean Hsu
1,028 次查看
Bio_TICFSL
