How to add software decoder on Android4.2.2 of the fsl_imx_omx?
1,708 次查看
fdact
Dear all,
      I need add other software decoder to support diff video formats on Android4.2.2, Can you tell me how to add sw decoder on FSL Multimedia framework?
Thanks.
标记 (1)
5 回复数
1,545 次查看
Hi ferdinand
please contact local marketing for fsl_imx_omx sources.
Note, for sw decoder codecs one can use Android native codecs,
just find necessary codec using google :"android codec free download"
1,545 次查看
fdact
Dear igorpadykov,
        "Note, for sw decoder codecs one can use Android native codecs,"
         But we have two problem:
         1. Our code only can find fsl_imx_omx file that means the media use fsl multimedia framework not stagefright.         So how to change the media framework to use stagefright?
         2.  I think you said "use Android native codecs" that means to use android stagefright framework, right?
Thanks.
1,545 次查看
In rootfs, there are two files in system/etc which used to control whether opencore will use
omx(fslomx.cfg), and which fsl omx component will be present in system(ComponentRegistry.txt).
Right, "use Android native codecs" means own android multimedia framework.
1,545 次查看
fdact
Dear igorpadykov,
      I didn't find fslomx.cfg and ComponentRegistry.txt in the system/etc and source code.
Thanks.
1,545 次查看
I am afraid any development with omx is out of scope community
support, suggest to apply to NXP Professional Services:
http://www.nxp.com/support/nxp-professional-services:PROFESSIONAL-SERVICE
Pro-Support contract www.nxp.com/prosupport
