How to add rt-linux patch to krikstone linux 5.15.52 in yocto for iMX8MP eval board
shravankumaralugala
I am build yocto for iMX8MP board I would like to add rt-linux patch to kernel but I found rt-patches are
not matching with the availble kernel with in imx repo.
Kindly suggest which version of iMX kernel is matching with the availble rt patches.
Dhruvit
Hi @shravankumaralugala,
I hope you are doing well
Kindly suggest which version of iMX kernel is matching with the available rt patches.
=> Please find the below document for the rt patches and the supported version
Thanks & Regards,
Dhruvit Vasavada
shravankumaralugala
Thanks for the prompt help.
Do you have rt support rt patch for latest kernel = >5.15. Right now no rt linux available for latest kernel >= 5.15 correct me if I am wrong, Are you going to release any RT linux/ RT patch for latest kernel in future.
Dhruvit
I hope you are doing well.
Please look at the below document for the changes related to "PREEMPT_RT".
I hope it helps you.
Thanks & Regards,
Dhruvit Vasavada
shravankumaralugala
Hi Dhruvit Vasavada,
Thanks for your response. From the Link you provide I understand that "community decided to merge the PREEMPT_RT kernel changes into mainline." Can you please provide tentative release date.
Dhruvit
Can you please provide a tentative release date.
=> There is no data related to the tentative release date.
My apology for the inconvenience.
Thanks & Regards,
Dhruvit Vasavada
