I'm about going to use libnfc-nci to driver PN7160-EVK on IMX8MPLUS-EVK. And I want to add libnfc-nci into yocto image and the sdk for imx-image-multimedia. Is any clue for me?
Actually i cannot build libnfc-nci in on IMX8MPLUS-EVK with image of imx-image-multimedia. Therefore, I want add it into yocto image directly.
Thanks very much!
Solved! Go to Solution.
 Rita_Wang
			Rita_Wang
 Rita_Wang
			Rita_Wang
		Could you tell me which version BSP are you using? I will confirmed with our NFC engineer tomorrow and then give you update.
