How to add audio driver to IMX53qsb
Showing results forย
Search instead forย
Did you mean:ย
prannoy
I am using IMX53 qsb board. I want add a new audio driver to the kernel.
kernel version is 2.6.35.
I have source code of that audio driver, I want to add over the spi interface.
Can you please help me.
fabio_estevam
Audio via sgtl5000 codec works by default o FSL kernel or mainline kernel.
igorpadykov
Hi prannoy
please check Chapter 21 "Porting Audio Codecs to a Custom Board"
MX53UG
However before porting I would suggest to check hardware and codes with OBDS
On-Board Diagnostic Suit for the i.MX53 Quick Start Board
chip
