How to add a new partition ?
1,971 次查看
snailqian
Hi, experts :
I need to add a new partition for special purpose,
Could you like to tell me which code/files should be add/modify ?
Thank you very much.
标签 (4)
4 回复数
1,733 次查看
SergioSolis
Hello Snail Qian,
Can you please give us more information?, are you referring to linux or android?
1,733 次查看
snailqian
Hi, expert:
Thank you for your reply.
Our platform is iMXDL and it is related to linux/android.
In our project ,we want to protect some important data, such as BT address ,Serial No. ,and so on. We hope those data can never be modified after factory written.
Therefore ,we plan to add a new special partition to store the important data, and this partition will be locked and not allow to write unless user know how to unlock it.
However ,we just begin to study your platform ,not very familiar with it. So ,I need your help to learn how to add a new partition which can be set to write-protect . Thanks a lot
1,733 次查看
jimmychan
you can use 'fdisk' command  to setup the partition.
if you are using MFGtool, you can modify the partitioning script "mksdcard.sh.tar" or "mksdcard-android.sh.tar".
1,733 次查看
snailqian
Dear Jimmy :
Thank you very much. get it :smileyhappy:
Additionally, one issue I need your information:
This partition is for storing important data, so we hope it can provide "write-protect" feature. In some other platforms which we developed on,
write-protect partitions should be aligned (it meas the size of this partition should be multiple of a special value).
I want to know ,whether iMXDL has such size limitation for "write-protect"partition ? Thanks.
