How to activate HAB on imx8dxl ?
1,637件の閲覧回数
pigbrian
Dear Guys,
I already enabled HAB in imx8mp, but imx8dxl doesn't have enough information about HAB.
1. imx-mkimage doesn't support the print_fit_hab option for imx8dxl.
2. I can't find a way to fuse the register map for imx8dxl online.
Could you please explain how to activate HAB?
Thank you.
1,609件の閲覧回数
Harvey021
Hi @pigbrian
The i.MX8DXL is with AHAB-enabled devices, and the boot images consist of containers.
That is different from i.MX8MP. The mx8_mx8x_secure_boot.txt and AN12312 can help for you.
About fuse and fusemap, the SRM can be found from https://www.nxp.com/products/iMX8XLite
Send you guide how to apply for that.
Harvey
15 返答(返信)
1,555件の閲覧回数
pigbrian
Hi, Harvey
I was found a option as below.
setenv force_prog_ecc y
When I search websites, IMX8MP using HAB4.
Can IMX8MP use AHAB ?
1,527件の閲覧回数
Harvey021
Hi @pigbrian
The AHAB not applied to i.MX8MP so can't use AHAB.
The AHAB events (IND = AHAB_BAD_SIGNATURE_IND (0xF0)) means that bad signature during the signature generation.
You can use the "FB: ucmd fuse prog -y 0 730 0x311D12F2" in your uuu script.
Harvey
1,474件の閲覧回数
pigbrian
Dear Harvey,
you are right.
I wrote some incorrect keys.
Can I fix a fused key?
1,472件の閲覧回数
pigbrian
Dear Harvey,
When I compared keys "od -t x4 ettifos_cits_fuse.bin" with "fuse read 0 730 16", all of keys are same.
Why happened "IND = AHAB_BAD_SIGNATURE_IND (0xF0)" ?
1,465件の閲覧回数
Harvey021
The IND = AHAB_BAD_SIGNATURE_IND (0xF0) tells Bad signature not the key hash error.
The AN12312 provides help.
Please check again the signature procedure.
Harvey
1,448件の閲覧回数
pigbrian
Dear harvey,
Now, I trying kernel signing.
According to sign_os_cntr.txt,
Note: OS image can also be authenticated by running a U-Boot command:
=> auth_cntr <Container address>
How to check <Container address> ?
I made a singed.Image with guide document and copy to {board}/boot/Image.
but, I met a problem as follow.
Bad Linux ARM64 Image magic!
=> ahab_status
Lifecycle: 0x0080, OEM closed
sc_seco_get_event: idx: 0, res:3
No SECO Events Found!
What should I check?
BR,
1,446件の閲覧回数
pigbrian
Dear Harvey.
1. auth_cntr <Container address>
solved.
=> ext2load mmc 0:2 0x98000000 /boot/Image_signed
28539904 bytes read in 149 ms (182.7 MiB/s)
=> auth_cntr 0x98000000
Authenticate OS container at 0x98000000
=> ext2load mmc 0:2 0x80700000 /boot/imx8dxl-v2x.dtb
54417 bytes read in 5 ms (10.4 MiB/s)
created some env parameters
fdtcontroladdr=87a540d0
fileaddr=80280000
filesize=1b28200
=> booti 0x80280000 - 0x80700000
BR,
1,250件の閲覧回数
Harvey021
Please check again the relevant envi configuration in uboot.
and have you loaded them?
pri bsp_bootcmd
bsp_bootcmd=echo Running BSP bootcmd ...; mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if test ${sec_boot} = yes; then if run loadcntr; then run mmcboot; else run netboot; fi; else if run loadimage; then run mmcboot; else run netboot; fi; fi; fi; fi;
Harvey
1,244件の閲覧回数
pigbrian
Dear Harvey,
I completed secure boot of IMX8DXL and IMX8MP.
Thank you for your help.
1,559件の閲覧回数
pigbrian
Dear Harvey,
This is my step.
ahab_status
Lifecycle: 0x0020, NXP closed
SECO Event[0] = 0x0087F000
CMD = AHAB_AUTH_CONTAINER_REQ (0x87)
sc_seco_get_event: idx: 1, res:3
The fuse command need to "y" prompt as follow.
=> fuse prog 0 730 0x311d12f2
Programming bank 0 word 0x000002da to 0x311d12f2...
Warning: Programming fuses is an irreversible operation!
This may brick your system.
Use this command only if you are sure of what you are doing!
Really perform this fuse programming? <y/N>
y
Warning: Words in this index range have ECC protection
and can only be programmed once per word. Individual bit
operations will be rejected after the first one.
Really program this word? <y/N>
And I used "-y" option. but it's need one "y" prompt
=> fuse prog -y 0 731 0x7c530a0d
Programming bank 0 word 0x000002db to 0x7c530a0d...
I made a uuu script as below.
It's failed.
1:242 1/17 [Bulk(R):LIBUSB_ERROR_TIMEOUT ] FB: ucmd fuse prog -y 0 730 0x311D12F2
What method should we use when we mass produce?
BR,
1,603件の閲覧回数
pigbrian
Dear Harvey,
Now, I was modified CSF offset and Signature Block offset on csf_ahab.txt
It was successfully.
cst-3.1.0/release/linux64/bin$ ./cst -o boot_ahab.bin -i cits_ahab.txt
CSF Processed successfully and signed image available in boot_ahab.bin
If I meet a problem, I write a reply.
Thank you.
1,591件の閲覧回数
Harvey021
Hi @pigbrian
Please let me know if further support needed.
Harvey
1,604件の閲覧回数
pigbrian
Hi, Harvey
Thank you for your reply.
I tried with your comment.
$ cd <work>/imx-mkimage
$ make SOC=iMX8DXL REV=A0 flash
mkimage_imx8 -soc DXL -rev A0 -append mx8dxlb0-ahab-container.img -c -scfw scfw_tcm.bin -ap u-boot-atf.bin a35 0x80000000 -dummy 0x87fc0000 -out flash.bin
[ERROR] CST: Offsets are not consistent with the input binary to be signed
__________
$ make SOC=iMX8DXL REV=B0 flash_spl
SPL_CMD="-ap u-boot-spl.bin_split_a a35 0x00100000 -data u-boot-spl.bin_split_b a35 0x110000"; \
./../mkimage_imx8 -soc DXL -rev A0 -dcd skip -append mx8dxlb0-ahab-container.img -c -scfw scfw_tcm.bin $SPL_CMD -dummy 0x110000 -out flash.bin
How do I create a signed image with mkimage?
BR,
pigbrian
1,606件の閲覧回数
pigbrian
Hi, Harvey
BR,
pigbrian
1,610件の閲覧回数
Harvey021
Hi @pigbrian
Harvey
%3CLINGO-SUB%20id%3D%22lingo-sub-2169267%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx8dxl%20%E3%81%A7%20HAB%20%E3%82%92%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E5%8C%96%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2169267%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%9A%86%E3%81%95%E3%82%93%E3%81%B8%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Eimx8mp%20%E3%81%A7%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%20HAB%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81imx8dxl%20%E3%81%AB%E3%81%AF%20HAB%20%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%8D%81%E5%88%86%E3%81%AA%E6%83%85%E5%A0%B1%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E1.%20imx-mkimage%20%E3%81%AF%20imx8dxl%20%E3%81%AE%20print_fit_hab%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E2.%20imx8dxl%20%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E8%9E%8D%E5%90%88%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EHAB%20%E3%82%92%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E5%8C%96%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2172541%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20activate%20HAB%20on%20imx8dxl%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172541%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%8F%E3%83%BC%E3%83%B4%E3%82%A7%E3%82%A4%E6%A7%98%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EIMX8DXL%E3%81%A8IMX8MP%E3%81%AE%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%82%92%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2172534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20activate%20HAB%20on%20imx8dxl%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3Euboot%20%E5%86%85%E3%81%AE%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%20envi%20%E6%A7%8B%E6%88%90%E3%82%92%E5%86%8D%E5%BA%A6%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3Epri%20bsp_bootcmd%3CBR%20%2F%3E%20bsp_bootcmd%3Decho%20BSP%20bootcmd%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3B%20mmc%20dev%20%24%7Bmmcdev%7D%20%3B%20mmc%20rescan%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%20loadbootscript%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81bootscript%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%20test%20%24%7Bsec_boot%7D%20%3D%20yes%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81loadcntr%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%20mmcboot%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%20netboot%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82fi%3B%20%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%20loadimage%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82mmcboot%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%20netboot%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82fi%3B%20fi%3B%20fi%3B%20fi%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2170819%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20activate%20HAB%20on%20imx8dxl%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170819%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%E3%83%8F%E3%83%BC%E3%83%B4%E3%82%A7%E3%82%A4%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E4%BB%8A%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E7%BD%B2%E5%90%8D%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E1.%20auth_cntr%3CCONTAINER%20address%3D%22%22%3E%3CBR%20%2F%3E%20%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FCONTAINER%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3D%26gt%3B%20ext2load%20mmc%200%3A2%200x98000000%20%2Fboot%2FImage_signed%3CBR%20%2F%3E%2028539904%E3%83%90%E3%82%A4%E3%83%88%E3%82%92149%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88182.7%20MiB%2F%E7%A7%92%EF%BC%89%3C%2FP%3E%3CP%3E%3D%26gt%3B%20%E8%AA%8D%E8%A8%BC%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%200x98000000%3CBR%20%2F%3E%200x98000000%20%E3%81%A7%20OS%20%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%E3%82%92%E8%AA%8D%E8%A8%BC%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%3D%26gt%3B%20ext2load%20mmc%200%3A2%200x80700000%20%2Fboot%2Fimx8dxl-v2x.dtb%3CBR%20%2F%3E5%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%2054417%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%20(10.4%20MiB%2F%E7%A7%92)%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AEenv%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Efdt%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3D87a540d0%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3D80280000%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%3D1b28200%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3D%26gt%3B%20%E3%83%96%E3%83%BC%E3%83%88%200x80280000%20-%200x80700000%3CBR%20%2F%3E%E6%82%AA%E3%81%84%20Linux%20ARM64%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%83%9E%E3%82%B8%E3%83%83%E3%82%AF!%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E4%BD%95%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%E3%80%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2170797%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20activate%20HAB%20on%20imx8dxl%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170797%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%8F%E3%83%BC%E3%83%B4%E3%82%A7%E3%82%A4%E6%A7%98%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BB%8A%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E7%BD%B2%E5%90%8D%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Esign_os_cntr.txt%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%3C%2FP%3E%3CP%3E%E6%B3%A8%3A%20OS%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AF%E3%80%81U-Boot%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E8%AA%8D%E8%A8%BC%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82CAN%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3D%26gt%3B%20auth_cntr%3CCONTAINER%20address%3D%22%22%3E%3C%2FCONTAINER%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CCONTAINER%20address%3D%22%22%3E%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FCONTAINER%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%AC%E3%82%A4%E3%83%89%20%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E5%90%AB%E3%82%80%20signed.Image%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%7Bboard%7D%2Fboot%2FImage%20%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%82%AA%E3%81%84%20Linux%20ARM64%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%83%9E%E3%82%B8%E3%83%83%E3%82%AF!%3CBR%20%2F%3E%20%3D%26gt%3B%20ahab_status%3CBR%20%2F%3E%E3%83%A9%E3%82%A4%E3%83%95%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%3A%200x0080%E3%80%81OEM%20%E7%B5%82%E4%BA%86%3C%2FP%3E%3CP%3Esc_seco_get_event%3A%20idx%3A%200%E3%80%81res%3A3%3CBR%20%2F%3E%20SECO%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%95%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2170753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20activate%20HAB%20on%20imx8dxl%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIND%20%3D%20AHAB_BAD_SIGNATURE_IND%20(0xF0)%20%E3%81%AF%E3%80%81%E3%82%AD%E3%83%BC%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E7%BD%B2%E5%90%8D%E3%81%8C%E4%B8%8D%E6%AD%A3%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN12312%26amp%3Blocation%3Dnull%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN12312%3C%2FA%3E%E3%81%8C%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E7%BD%B2%E5%90%8D%E6%89%8B%E9%A0%86%E3%82%92%E5%86%8D%E5%BA%A6%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EHarvey%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2170726%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20activate%20HAB%20on%20imx8dxl%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170726%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%8F%E3%83%BC%E3%83%B4%E3%82%A7%E3%82%A4%E6%A7%98%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%AD%E3%83%BC%E3%80%8C%20%3CSPAN%3Eod%20-t%20x4%20ettifos_cits_fuse.bin%E3%80%8D%E3%81%A8%E3%82%AD%E3%83%BC%E3%80%8Cfuse%20read%200%20730%2016%E3%80%8D%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%AD%E3%83%BC%E3%81%8C%E5%90%8C%E3%81%98%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20%E3%80%8CIND%20%3D%20AHAB_BAD_SIGNATURE_IND%20(0xF0)%E3%80%8D%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2170715%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20activate%20HAB%20on%20imx8dxl%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170715%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%8F%E3%83%BC%E3%83%B4%E3%82%A7%E3%82%A4%E6%A7%98%3CBR%20%2F%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CSPAN%3EAHAB%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%20(%3C%2FSPAN%3E%3CSPAN%3EIND%20%3D%20AHAB_BAD_SIGNATURE_IND%20(0xF0)%3C%2FSPAN%3E%3CSPAN%3E)%20%E3%81%AF%E3%80%81%E7%BD%B2%E5%90%8D%E7%94%9F%E6%88%90%E4%B8%AD%E3%81%AB%E4%B8%8D%E6%AD%A3%E3%81%AA%E7%BD%B2%E5%90%8D%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E3%82%AD%E3%83%BC%E3%82%92%E6%9B%B8%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ECAN%E6%BA%B6%E3%81%91%E3%81%9F%E3%82%AD%E3%83%BC%E3%82%92%E4%BF%AE%E7%90%86%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2170314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20activate%20HAB%20on%20imx8dxl%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F228774%22%20target%3D%22_blank%22%3E%40pigbrian%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EAHAB%20%E3%81%AF%20i.MX8MP%20%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81AHAB%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3EAHAB%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%20(%20%3CSPAN%3EIND%20%3D%20AHAB_BAD_SIGNATURE_IND%20(0xF0)%3C%2FSPAN%3E%20)%20%E3%81%AF%E3%80%81%E7%BD%B2%E5%90%8D%E7%94%9F%E6%88%90%E4%B8%AD%E3%81%AB%E4%B8%8D%E6%AD%A3%E3%81%AA%E7%BD%B2%E5%90%8D%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3Euuu%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%A7%E3%80%8C%20%3CSPAN%3EFB%3A%20ucmd%20fuse%20prog%20-y%200%20730%200x311D12F2%3C%2FSPAN%3E%20%E3%80%8D%E3%82%92CAN%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2170064%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20activate%20HAB%20on%20imx8dxl%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170064%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%8F%E3%83%BC%E3%83%B4%E3%82%A7%E3%82%A4%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Esetenv%20force_prog_ecc%20y%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%A6%E3%82%A7%E3%83%96%E3%82%B5%E3%82%A4%E3%83%88%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81HAB4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6IMX8MP%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EIMX8MP%E3%81%AFAHAB%E3%82%92%E4%BD%BF%E7%94%A8CAN%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2170012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20activate%20HAB%20on%20imx8dxl%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%8F%E3%83%BC%E3%83%B4%E3%82%A7%E3%82%A4%E6%A7%98%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Eahab_status%3CBR%20%2F%3E%E3%83%A9%E3%82%A4%E3%83%95%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%3A%200x0020%E3%80%81NXP%20%E7%B5%82%E4%BA%86%3C%2FP%3E%3CP%3ESECO%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%5B0%5D%20%3D%200x0087F000%3CBR%20%2F%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%3D%20AHAB_AUTH_CONTAINER_REQ%20(0x87)%3CBR%20%2F%3E%20IND%20%3D%20AHAB_BAD_SIGNATURE_IND%20(0xF0)%3C%2FP%3E%3CP%3Esc_seco_get_event%3A%20idx%3A%201%E3%80%81res%3A3%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Efuse%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%80%8Cy%E3%80%8D%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3D%26gt%3B%20%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%200%20730%200x311d12f2%3CBR%20%2F%3E%E3%83%90%E3%83%B3%E3%82%AF%200%20%E3%83%AF%E3%83%BC%E3%83%89%200x000002da%20%E3%81%8B%E3%82%89%200x311d12f2%20%E3%81%BE%E3%81%A7%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AF%E5%85%83%E3%81%AB%E6%88%BB%E3%81%9B%E3%81%AA%E3%81%84%E6%93%8D%E4%BD%9C%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E5%A3%8A%E3%82%8C%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E8%87%AA%E5%88%86%E3%81%8C%E4%BD%95%E3%82%92%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E7%A2%BA%E4%BF%A1%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AE%E3%81%BF%E3%80%81%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%92%E6%9C%AC%E5%BD%93%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%26lt%3B%E3%81%AF%E3%81%84%2F%E3%81%84%E3%81%84%E3%81%88%26gt%3B%3CBR%20%2F%3E%20y%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%E3%81%93%E3%81%AE%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E7%AF%84%E5%9B%B2%E3%81%AE%E5%8D%98%E8%AA%9E%E3%81%AB%E3%81%AFECC%E4%BF%9D%E8%AD%B7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E5%8D%98%E8%AA%9E%E3%81%94%E3%81%A8%E3%81%AB%201%20%E5%9B%9E%E3%81%A0%E3%81%91%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E5%80%8B%E3%80%85%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%3CBR%20%2F%3E%E6%9C%80%E5%88%9D%E3%81%AE%E6%93%8D%E4%BD%9C%E4%BB%A5%E9%99%8D%E3%81%AE%E6%93%8D%E4%BD%9C%E3%81%AF%E6%8B%92%E5%90%A6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E6%9C%AC%E5%BD%93%E3%81%AB%E3%81%93%E3%81%AE%E5%8D%98%E8%AA%9E%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%26lt%3B%E3%81%AF%E3%81%84%2F%E3%81%84%E3%81%84%E3%81%88%26gt%3B%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%80%8C-y%E3%80%8D%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%22y%22%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%81%8C1%E3%81%A4%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3D%26gt%3B%20%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%20-y%200%20731%200x7c530a0d%3CBR%20%2F%3E%E3%83%90%E3%83%B3%E3%82%AF%200%20%E3%83%AF%E3%83%BC%E3%83%89%200x000002db%20%E3%82%92%200x7c530a0d%20%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%E3%81%93%E3%81%AE%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E7%AF%84%E5%9B%B2%E3%81%AE%E5%8D%98%E8%AA%9E%E3%81%AB%E3%81%AFECC%E4%BF%9D%E8%AD%B7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E5%8D%98%E8%AA%9E%E3%81%94%E3%81%A8%E3%81%AB%201%20%E5%9B%9E%E3%81%A0%E3%81%91%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E5%80%8B%E3%80%85%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%3CBR%20%2F%3E%E6%9C%80%E5%88%9D%E3%81%AE%E6%93%8D%E4%BD%9C%E4%BB%A5%E9%99%8D%E3%81%AE%E6%93%8D%E4%BD%9C%E3%81%AF%E6%8B%92%E5%90%A6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E6%9C%AC%E5%BD%93%E3%81%AB%E3%81%93%E3%81%AE%E5%8D%98%E8%AA%9E%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%26lt%3B%E3%81%AF%E3%81%84%2F%E3%81%84%E3%81%84%E3%81%88%26gt%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AAuuu%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EFB%3A%20ucmd%20fuse%20prog%20-y%200%20730%200x311D12F2%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E1%3A242%201%2F17%20%5BBulk(R)%3ALIBUSB_ERROR_TIMEOUT%5D%20FB%3A%20ucmd%20fuse%20prog%20-y%200%20730%200x311D12F2%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%A4%A7%E9%87%8F%E7%94%9F%E7%94%A3%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E6%96%B9%E6%B3%95%E3%82%92%E6%8E%A1%E7%94%A8%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2169637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20activate%20HAB%20on%20imx8dxl%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2169637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F228774%22%20target%3D%22_blank%22%3E%40pigbrian%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2169444%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20activate%20HAB%20on%20imx8dxl%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2169444%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%8F%E3%83%BC%E3%83%B4%E3%82%A7%E3%82%A4%E6%A7%98%3C%2FP%3E%3CP%3E%E3%81%95%E3%81%A6%E3%80%81csf_ahab.txt%E3%81%AECSF%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%81%A8%E7%BD%B2%E5%90%8D%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Ecst-3.1.0%2F%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%2Flinux64%2Fbin%24.%2Fcst-o%20boot_ahab.bin%20-i%20cits_ahab.txt%3CBR%20%2F%3ECSF%20%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%80%81%E7%BD%B2%E5%90%8D%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AF%20boot_ahab.bin%20%E3%81%A7%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E8%BF%94%E4%BF%A1%E3%82%92%E6%9B%B8%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2169437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20activate%20HAB%20on%20imx8dxl%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2169437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%8F%E3%83%BC%E3%83%B4%E3%82%A7%E3%82%A4%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%24%20cd%3CWORK%3E%20%2Fimx-mkimage%3CBR%20%2F%3E%20%24%20SOC%3DiMX8DXL%20REV%3DA0%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E4%BD%9C%E6%88%90%3C%2FWORK%3E%3C%2FP%3E%3CP%3Emkimage_imx8%20-soc%20DXL%20-rev%20A0%20-append%20mx8dxlb0-ahab-container.img%20-c%20-scfw%20scfw_tcm.bin%20-ap%20u-boot-atf.bin%20a35%200x80000000%20-dummy%200x87fc0000%20-out%20flash.bin%3CBR%20%2F%3E~~~%3CBR%20%2F%3E%20cst-3.1.0%2F%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%2Flinux64%2Fbin%24.%2Fcst-o%20boot_ahab.bin%20-i%20cits_ahab.txt%3C%2FP%3E%3CP%3E%5B%E3%82%A8%E3%83%A9%E3%83%BC%5D%20CST%3A%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E3%80%81%E7%BD%B2%E5%90%8D%E3%81%99%E3%82%8B%E5%85%A5%E5%8A%9B%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E__________%3C%2FP%3E%3CP%3E%24%20SOC%3DiMX8DXL%20REV%3DB0%20flash_spl%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3ESPL_CMD%3D%22-ap%20u-boot-spl.bin_split_aa35%200x00100000%20-data%20u-boot-spl.bin_split_ba35%200x110000%22%3B%20%5C%3CBR%20%2F%3E%20.%2F..%2Fmkimage_imx8%20-soc%20DXL%20-rev%20A0%20-dcd%20skip%20-append%20mx8dxlb0-ahab-container.img%20-c%20-scfw%20scfw_tcm.bin%20%24SPL_CMD%20-dummy%200x110000%20-out%20flash.bin%3CBR%20%2F%3E~~~%3CBR%20%2F%3E%20cst-3.1.0%2F%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%2Flinux64%2Fbin%24.%2Fcst-o%20boot_ahab.bin%20-i%20cits_ahab.txt%3CBR%20%2F%3E%5B%E3%82%A8%E3%83%A9%E3%83%BC%5D%20CST%3A%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E3%80%81%E7%BD%B2%E5%90%8D%E3%81%99%E3%82%8B%E5%85%A5%E5%8A%9B%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%3CBR%20%2F%3Emkimage%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%BD%B2%E5%90%8D%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%20BR%E3%80%81%3C%2FP%3E%3CP%3E%E3%83%94%E3%83%83%E3%82%B0%E3%83%96%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2169402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20activate%20HAB%20on%20imx8dxl%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2169402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%8F%E3%83%BC%E3%83%B4%E3%82%A7%E3%82%A4%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%24%20cd%3CWORK%3E%20%2Fimx-mkimage%3CBR%20%2F%3E%20%24%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3ESOC%3DiMX8DXL%3C%2FSPAN%3E%3CSPAN%3E%20REV%3DA0%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%3C%2FSPAN%3E%3C%2FWORK%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emkimage_imx8%20-soc%20DXL%20-rev%20A0%20-append%20mx8dxlb0-ahab-container.img%20-c%20-scfw%20scfw_tcm.bin%20-ap%20u-boot-atf.bin%20a35%200x80000000%20-dummy%200x87fc0000%20-out%20flash.bin%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E~~~%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ecst-3.1.0%2F%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%2Flinux64%2Fbin%24.%2Fcst-o%20boot_ahab.bin%20-i%20cits_ahab.txt%3C%2FP%3E%3CP%3E%5B%E3%82%A8%E3%83%A9%E3%83%BC%5D%20CST%3A%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E3%80%81%E7%BD%B2%E5%90%8D%E3%81%99%E3%82%8B%E5%85%A5%E5%8A%9B%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Emkimage%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%BD%B2%E5%90%8D%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%E3%80%81%3C%2FP%3E%3CP%3E%E3%83%94%E3%83%83%E3%82%B0%E3%83%96%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2169367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20activate%20HAB%20on%20imx8dxl%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2169367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F228774%22%20target%3D%22_blank%22%3E%40pigbrian%3C%2FA%3E%3C%2FP%3E%0A%3CP%3Ei.MX8DXL%20%E3%81%AF%20AHAB%20%E5%AF%BE%E5%BF%9C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E6%90%AD%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AF%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%E3%83%BC%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AFi.MX8MP%E3%81%A8%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fuboot-imx%2Fblob%2Flf_v2025.04%2Fdoc%2Fimx%2Fahab%2Fguides%2Fmx8_mx8x_secure_boot.txt%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Emx8_mx8x_secure_boot.txt%3C%2FA%3E%E3%81%A8%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN12312%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN12312%20%E3%81%8C%3C%2FA%3ECAN%E3%80%82%3C%2FP%3E%0A%3CP%3Efuse%E3%81%A8fusemap%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81SRM%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2FiMX8XLite%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2FiMX8XLite%3C%2FA%3E%E3%81%8B%E3%82%89CAN%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%94%B3%E8%AB%8B%E6%96%B9%E6%B3%95%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%9F%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E3%81%8A%E9%80%81%E3%82%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
