How to Interface the NXP PN7160 NFC Module With the i.MX8M Plus EVK?
2,031件の閲覧回数
Niranjan123
I am working with an i.MX8M Plus EVK and planning to integrate the NXP PN7160 NFC controller (using the PN7160 Raspberry Pi HAT: OM29110RPI-B).
regards,
Niranjan
3 返答(返信)
1,969件の閲覧回数
danielchen
HI, @Niranjan123
If you are using Android, please refer to below link  ,  it is about porting PN7160 with i.MX8M nano,
https://community.nxp.com/t5/NFC-Knowledge-Base/Porting-PN7160-to-Android-14-on-i-MX8M-Nano-board/ta...
1,943件の閲覧回数
Niranjan123
Thank you for the link, but I am not using Android.
My setup is:
  • Board: i.MX8M Plus EVK
  • OS: Linux (Yocto-based Linux BSP from NXP, not Android)
  • NFC Module: PN7160 Raspberry Pi HAT (OM29110RPI-B)
  • Connection: I2C interface from the EVK expansion header to PN7160 HAT pins
My goal is to bring up the PN7160 in a Linux environment, using the NXP PN7160 Linux driver.
Could you please clarify the following for Linux (Yocto) on i.MX8MP EVK:
  1. Does NXP provide a Linux driver (kernel or user-space) for PN7160 that can be used on i.MX applications processors?
  2. If yes, where can I find the recommended
    • device-tree binding
    • required GPIOs (VEN / IRQ)
    • Linux kernel config options
    • sample DTS node for PN7160?
  3. Which I2C bus on the i.MX8MP EVK expansion connector is recommended for connecting external modules like PN7160?
    (There is no Raspberry Pi 40-pin header on this board, so I want to confirm the correct I2C bus.)
  4. Are there any known reference implementations of PN7160 running on an i.MX8M Plus EVK (under Linux)?
Current status on my side:
  • Verified I2C buses available: /dev/i2c-0, /dev/i2c-1, /dev/i2c-2, /dev/i2c-6
  • Expansion header signals checked in schematic
  • Planning to use I2C2 or I2C1 depending on recommended wiring
  • Before wiring PN7160 HAT, I want NXP confirmation on:
    ✔ Correct I2C bus
    ✔ Required voltage levels
    ✔ Required IRQ and VEN GPIO pins
Any guidance for Linux + PN7160 + i.MX8MP would be very helpful.
Thanks!
タグ(1)
1,926件の閲覧回数
danielchen
Hi @Niranjan123
Please refer to below PN7160 Linux porting guide,    You can get the Linux driver and device tree information from below porting duide.
%3CLINGO-SUB%20id%3D%22lingo-sub-2232731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENXP%20PN7160%20NFC%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%20i.MX8M%20Plus%20EVK%20%E3%81%A8%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2232731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%3CSTRONG%3Ei.MX8M%20Plus%20EVK%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%20%3CSTRONG%3ENXP%20PN7160%20NFC%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FSTRONG%3E(PN7160%20Raspberry%20Pi%20HAT%3A%20OM29110RPI-B%20%E3%82%92%E4%BD%BF%E7%94%A8)%20%E3%82%92%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%8B%E3%83%A9%E3%83%B3%E3%82%B8%E3%83%A3%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2246605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20Interface%20the%20NXP%20PN7160%20NFC%20Module%20With%20the%20i.MX8M%20Plus%20EVK%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2246605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F244755%22%20target%3D%22_blank%22%3E%40Niranjan123%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EAndroid%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81PN7160%E3%82%92i.MX8M%20nano%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNFC-Knowledge-Base%2FPorting-PN7160-to-Android-14-on-i-MX8M-Nano-board%2Fta-p%2F2001159%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNFC-Knowledge-Base%2FPorting-PN7160-to-Android-14-on-i-MX8M-Nano-board%2Fta-p%2F2001159%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2246785%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20Interface%20the%20NXP%20PN7160%20NFC%20Module%20With%20the%20i.MX8M%20Plus%20EVK%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2246785%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%3CSTRONG%3EAndroid%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%83%9C%E3%83%BC%E3%83%89%3A%3C%2FSTRONG%3E%20i.MX8M%20Plus%20EVK%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EOS%3A%3C%2FSTRONG%3E%20Linux%20(%20%3CEM%3EAndroid%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%3C%2FEM%3E%E3%80%81NXP%20%E3%81%AE%20Yocto%20%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%20Linux%20BSP)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3ENFC%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3A%3C%2FSTRONG%3E%20PN7160%20Raspberry%20Pi%20HAT%20(OM29110RPI-B)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E6%8E%A5%E7%B6%9A%3A%3C%2FSTRONG%3E%20EVK%E6%8B%A1%E5%BC%B5%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%8B%E3%82%89PN7160%20HAT%E3%83%94%E3%83%B3%E3%81%B8%E3%81%AEI2C%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E7%A7%81%E3%81%AE%E7%9B%AE%E6%A8%99%E3%81%AF%E3%80%81NXP%20PN7160%20Linux%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%20%3CSTRONG%3ELinux%20%E7%92%B0%E5%A2%83%3C%2FSTRONG%3E%E3%81%A7%20PN7160%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-2001562195%22%20id%3D%22toc-hId-2001614805%22%20id%3D%22toc-hId-2001614805%22%3E%3CSTRONG%3Ei.MX8MP%20EVK%20%E4%B8%8A%E3%81%AE%20Linux%20(Yocto)%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AE%E7%82%B9%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FSTRONG%3E%3C%2FH3%3E%3COL%3E%3CLI%3E%3CP%3E%3CSTRONG%3ENXP%20%E3%81%AF%E3%80%81i.MX%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%20PN7160%20%E7%94%A8%E3%81%AE%20Linux%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20(%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E7%A9%BA%E9%96%93)%20%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3C%2FSTRONG%3E%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%82%82%E3%81%97%E3%81%9D%E3%81%86%E3%81%AA%E3%82%89%E3%80%81%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7CAN%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%83%90%E3%82%A4%E3%83%B3%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%BF%85%E8%A6%81%E3%81%AAGPIO%EF%BC%88VEN%20%2F%20IRQ%EF%BC%89%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ELinux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EPN7160%20%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20DTS%20%E3%83%8E%E3%83%BC%E3%83%89%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CP%3EPN7160%20%E3%81%AA%E3%81%A9%E3%81%AE%E5%A4%96%E9%83%A8%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%20%3CSTRONG%3Ei.MX8MP%20EVK%20%E6%8B%A1%E5%BC%B5%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E4%B8%8A%E3%81%AE%E3%81%A9%E3%81%AE%20I2C%E3%83%90%E3%82%B9%20%E3%81%8C%3C%2FSTRONG%3E%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%20(%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%20Raspberry%20Pi%2040%20%E3%83%94%E3%83%B3%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%8C%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%20I2C%E3%83%90%E3%82%B9%20%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3Ei.MX8M%20Plus%20EVK%20(Linux)%20%E4%B8%8A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%20PN7160%20%E3%81%AE%3CSTRONG%3E%E6%97%A2%E7%9F%A5%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E5%AE%9F%E8%A3%85%E3%81%AF%3C%2FSTRONG%3E%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CH3%20id%3D%22toc-hId-194107732%22%20id%3D%22toc-hId-194160342%22%20id%3D%22toc-hId-194160342%22%3E%3CSTRONG%3E%E7%A7%81%E3%81%AE%E5%81%B4%E3%81%AE%E7%8F%BE%E5%9C%A8%E3%81%AE%E7%8A%B6%E6%B3%81%3A%3C%2FSTRONG%3E%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CP%3E%E6%A4%9C%E8%A8%BC%E6%B8%88%E3%81%BF%E3%81%AE%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%20I2C%20%E3%83%90%E3%82%B9%3A%20%2Fdev%2Fi2c-0%E3%80%81%2Fdev%2Fi2c-1%E3%80%81%2Fdev%2Fi2c-2%E3%80%81%2Fdev%2Fi2c-6%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%81%A7%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9F%E6%8B%A1%E5%BC%B5%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E4%BF%A1%E5%8F%B7%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%8E%A8%E5%A5%A8%E9%85%8D%E7%B7%9A%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6I2C2%E3%81%BE%E3%81%9F%E3%81%AFI2C1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EPN7160%20HAT%20%E3%82%92%E9%85%8D%E7%B7%9A%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81NXP%20%E3%81%AB%E6%AC%A1%E3%81%AE%E7%82%B9%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E3%80%82%3CBR%20%2F%3E%20%E2%9C%94%20%E6%AD%A3%E3%81%97%E3%81%84I2C%E3%83%90%E3%82%B9%3CBR%20%2F%3E%E2%9C%94%20%E5%BF%85%E8%A6%81%E3%81%AA%E9%9B%BB%E5%9C%A7%E3%83%AC%E3%83%99%E3%83%AB%3CBR%20%2F%3E%E2%9C%94%20%E5%BF%85%E8%A6%81%E3%81%AA%20IRQ%20%E3%81%8A%E3%82%88%E3%81%B3%20VEN%20GPIO%20%E3%83%94%E3%83%B3%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3ELinux%20%2B%20PN7160%20%2B%20i.MX8MP%3C%2FSTRONG%3E%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%AC%E3%82%A4%E3%83%80%E3%83%B3%E3%82%B9%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2246806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20Interface%20the%20NXP%20PN7160%20NFC%20Module%20With%20the%20i.MX8M%20Plus%20EVK%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2246806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F244755%22%20target%3D%22_blank%22%3E%40Niranjan123%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%20PN7160%20Linux%20%E7%A7%BB%E6%A4%8D%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82Linux%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%A7%BB%E6%A4%8D%E3%82%AC%E3%82%A4%E3%83%89%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fdocs%2Fen%2Fapplication-note%2FAN13287.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EPN7160%20Linux%E7%A7%BB%E6%A4%8D%E3%82%AC%E3%82%A4%E3%83%89%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E
