How to Flash both Free RTOS on M4 and Android13 on A53
1,901 次查看
Hassan_Zafirul
I am using iMx8QM MEK board and want to flash FreeRTOS on M4 and Android13 on A53.
M4 will be controller Display1 for cluster and Display2  for IVI. Can you please share the links for prebuild binary.
7 回复数
1,759 次查看
Hassan_Zafirul
Hi Salas,
We followed the steps provided in User Guide and SDK and build the Hello_World program, We were able to flash using SD with M4 image and we are able to see it on console when we are trying to flash "uuu_imx_android_flash.sh" we are getting the mcu_os  error.
After investing more we found for  i.MX 8M Mini EVK Board - imx8mm_mcu_demo.img is available.
How can we build this for i.MX 8QM board, fast reply will help us.
With Regards
Zafirul Hassan
1,746 次查看
Manuel_Salas
One can try set the boot command in U-boot as:
setenv bootcmd "bootmcu && boota mmc0"
This thread can be helpful: https://community.nxp.com/t5/i-MX-Processors/IMX8MM-Loading-m4-image-along-with-Android/td-p/996855
Salas.
1,772 次查看
Hassan_Zafirul
 How to get the console for M4 running FreeRTOS
1,840 次查看
Hassan_Zafirul
Thanks Salas, From where i can get pre-built images to run FreeRTOS on Core-M4. Can you please provide the link
1,832 次查看
Manuel_Salas
You can refer to MCUXpresso SDK, there you can generate the SDKs for your processors, including FreeRTOS.
Salas.
1,809 次查看
Hassan_Zafirul
Hi Salas.
We have -m(flash MCU image) option with the uuu_imx_android_flash.sh script. Could you perhaps offer an example of how to use this option to flash the image together with the Android 13 image?
1,879 次查看
Manuel_Salas
Hello @Hassan_Zafirul
Please refer to this Application Note (AN5317) that is about Loading Code on Cortex-M from U-Boot/Linux for the i.MX Asymmetric Multi-Processing Application Processors.
Salas.
