How to Configure the USB1 of IMX28 as host mode default
已解决
跳至解决方案
1,274 次查看
liuxing
Hi all,
  I want to set the usb1 as host,and disable the otg function.However,the vbus can't be driver successfully.the DEVCTL.bit3 and DEVCTL.bit4 is always 0.
  How to configure the usb1's register?
标签 (1)
1 解答
1,183 次查看
Hi liu
for host mode settings please look at stmp_usbh.c in i.MX28 evk obds:
Lab and Test Software (1)
On-Board Diagnostic Suit for the i.MX28 (REV 1)
i.MX28 Evaluation Kit|Freescale
在原帖中查看解决方案
1 回复
1,184 次查看
Hi liu
