I am using rocko(kernel version: 4.9.88) distribution in yacto BSP for IMX8M EVK board with default ov5640 camera. Currently the default camera uses the virtual channel zero for receiving the mipi data.
I have two questions,
Thanks & Regrads,
Vimal
Hi Vimal
For i.MX8M MIPI virtual channel is not used, so the driver will not split the video from each virtual channel.
For dual camera one can check
Dual camera support for i.MX8M EVK
