How many gstreamer pipelines on imx8mm
1,005 次查看
matt67
How many gstreamer pipelines could run in parallel in order to decode/re-encode H264 video streams.
My usecases are to decode 4 FHD (1920x1080) RSTP video source and re-encode to :
HD (720x1080) or FWVGA (480x854) depending on user setting.
999 次查看
Hi Matthieu
from hardware there are no limitation, limitation only from internal buses bandwidth.
So guaranteed performance is 1080p60, but with less fps/resolutions there may be more vpu instances
for example two 1080p30.
