How many cycles of data saved on RALAT of i.MX6.
1,182 次查看
takashitakahash
Dear community.
I refered i.MX6DQ RM of  44.12.7 MMDC Core Miscellaneous Register  describe on RALAT ,
RALAT maximum value is 7, so is 7 cycles (data bus width of the xDRAM)max?
标签 (4)
1,020 次查看
Hi Takashi
RALAT accounts for board delays, with typical value =4.
One can change it slightly, based on results of ddr test.
Increasing RALAT will make ddr accesses slower.
1,021 次查看
Hi Takashi
