Hi lin,
The VPU requires a specific size resolution. If the size changes the VPU instance has to be reinitialized. This is because when the instance is instantiated physical memory is allocated based on the size specified. Please check .MX 6Dual/6Quad VPU Application Programming Interface Linux Reference Manual / Document Number:VPU_API
Hi lin,
