How do I add OpenCL support to Yocto build process for the imx6qsabresd?
6,614 次查看
tfarnham
I am trying to enable OpenCL support both in the target image as well as the SDK built using populate_sdk.  I am currently using the imx-3.14.28-1.0.0_ga BSP.  I have a "minimal" build working without OpenCL.  I don't have any gui elements included.  I would like to know what I might need to add in the way of layers and/or conf instructions to get OpenCL support using the vivante GPU enabled.  I really don't need wayland, x11, directfb etc....  Just GPU + OpenCL support.  I hope some expert with yocto+imx might have some clues for me....Thanks.
标签 (2)
4,957 次查看
tfarnham
I figured out some basics that have helped, but I still had to include directfb in my image.
Changed my conf to have:
DISTRO_FEATURES_remove = "x11 wayland"
DISTRO_FEATURES_append = " directfb"
Added this to my IMAGE_INSTALL:
packagegroup-core-directfb
fsl-gpu-sdk
4,958 次查看
tfarnham
fsl-gpu-sdk
4,957 次查看
Bio_TICFSL
Hi Terry
Also make sure that you have the graphics recipe and you are able to run those graphics unit test and fsl-gpu-sdk demos.
Also something to take in mind https://community.nxp.com/thread/428397
regards
