How can i code relocate from TCM to DDR in i.MX8M Mini?
616 次查看
Hariharan1
Hi Experts,
As of now, I initialized ddr memory which can be access upto 3GB. I don't want to run my program after ddr initialization using TCM. i prefer to run the program with DDR memory.
How can i achieve this activity?
Hariharan
580 次查看
Zhiming_Liu
Hi @Hariharan1
Even you load elf from remoteproc framework(in DDR), the data and segments are still mapped into TCM. For remoteproc use case, you can refer  AN5317.pdf
581 次查看
Zhiming_Liu
Hi @Hariharan1
