Hi,all friends,could someone tell me how to boot from nor flash using i.MX 6 SABRE-SD ? I've tried to fllow the doc <i.MX_Linux_User's_Guide.pdf> , but it could not work. By the way,i have changed the BT_CFG1_4, BT_CFG1_5, BT_CFG4_3, BT_CFG4_4 to high level. Could someone give me some suggestiongs , thanks a lot !
You can use the mfgtool to download the u-boot to nor flash, the details download process you can read the ucl2.xml file. When finish success download, you can change the boot mode to boot up from nor flash mode. Then boot up.
