How can i.MX 6 SABRE-SD boot from nor flash?
1,858 次查看
zhengjianfei
Hi,all friends,could someone tell me how to boot from nor flash using i.MX 6 SABRE-SD ?  I've tried to fllow the doc <i.MX_Linux_User's_Guide.pdf> , but it could not work. By the way,i have changed the BT_CFG1_4,  BT_CFG1_5,  BT_CFG4_3,  BT_CFG4_4  to high level. Could someone give me some suggestiongs , thanks a lot !
标记 (2)
4 回复数
1,663 次查看
素伟李
Can i.MX 6 SABRE-SD  support boot from nor flash?
1,663 次查看
Rita_Wang
1,663 次查看
Rita_Wang
You can use the mfgtool to download the u-boot to nor flash, the details download process you can read the ucl2.xml file. When finish success download, you can change the boot mode to boot up from nor flash mode. Then boot up.
1,663 次查看
Rita_Wang
Could you tell me which version BSP are you using?
