How can I use "gpiod.h" function on IMX8MQ-EVK
896件の閲覧回数
yumy
Hi, 我目前正在IMX8MQ-EVK上開發關於gpio的功能
需要在我的程式內偵測gpio某個pin腳(正在使用中)的電位
我在local.conf加了IMAGE_INSTALL:append = "libgpiod libgpiod-dev libgpiod-tools"來include "gpiod.h"
但使用像是下列範例程式
struct gpiod_chip; //GPIO chip
struct gpiod_line; //GPIO line
//获取GPIO控制器(GPIO组)
struct gpiod_chip *gpiod_chip_open(const char *path);
//获取GPIO引脚
struct gpiod_line * gpiod_chip_get_line(struct gpiod_chip *chip, unsigned int offset);
//读取引脚状态
int gpiod_line_get_value(struct gpiod_line *line);
卻顯示在gpiod.h沒定義gpiod_chip_get_line、gpiod_line_get_value等function
請問是我沒有將gpiod.h的資料include齊全嗎
有別的幫法可以使用gpiod.h的資料嗎
或者可以偵測gpio現在的value值
謝謝
848件の閲覧回数
Zhiming_Liu
The API change a lot, you should change your code refer example
https://github.com/brgl/libgpiod/tree/master/examples
