Hi igorpadykov,
Thanks for replay!
There are some questions:
1. Only set IMX8MQ_CLK_GPU_SHADER_SRC to 1000 MHz?
Is IMX8MQ_CLK_GPU_CORE_SRC, IMX8MQ_CLK_GPU_AXI_SRC, and IMX8MQ_CLK_GPU_AHB_SRC don't set to 1000 MHz?
2. The imx8mq datasheet say the gpu clcok if gets to 1G Hz, need 1V voltage
Will it auto adjust voltage to 1V, or need to do some setting manually?
