How can I set the HTMI output from landscape(default) to portrait
1,344 次查看
linux_downey
As the title,I'm developing a QT5 application and it must be displayed on a   portrait screen, I tried the QT rotation-API,But the results didn't meet my requirements ,and I wanted to switch the hdmi output to vertical display.
environment as below:
1.  i.mx8mq evk
2.  image name : fsl-image-qt5-validation-imx-imx8mqevk-20190923102914.rootfs.sdcard
3.  display with wayland.
thanks!
best regards.
downey
标记 (2)
1,272 次查看
Hi downey
one can look at suggestions provided on
Configuring Orientation of HDMI Display
1,273 次查看
Hi downey
1,272 次查看
linux_downey
Hi igorpadykov:
   It does works!
   Sooooooo appreciate for your nice advice.
downey
