How can I set the HTMI output from landscape(default) to portrait
linux_downey
As the title,I'm developing a QT5 application and it must be displayed on a   portrait screen, I tried the QT rotation-API,But the results didn't meet my requirements ,and I wanted to switch the hdmi output to vertical display.
environment as below:
1.  i.mx8mq evk
2.  image name : fsl-image-qt5-validation-imx-imx8mqevk-20190923102914.rootfs.sdcard
3.  display with wayland.
thanks!
best regards.
downey
Tags (2)
Hi downey
one can look at suggestions provided on
Configuring Orientation of HDMI Display
Hi downey
linux_downey
Hi igorpadykov:
   It does works!
   Sooooooo appreciate for your nice advice.
downey
