How can I set ADC reference voltage to 5v in imx6ull?
1,406 次查看
Majid
I'm using IMX6ULL  and I config it's ADC to working with 3.3v as reference.
Is it possible set reference voltage to 5v? If the answer is yes, How?
标签 (2)
1,404 次查看
weidong_sun
See below, please!
ADC reference voltage is fixed to be 3.3V, not 5V.
if your analog signal max level is 5V, use divider resistor, please!
Have a nice day!
B.R,
weidong
1,405 次查看
weidong_sun
See below, please!
Have a nice day!
B.R,
weidong
