How can I get the gpu infomation at i.MX8MP
2,238件の閲覧回数
jerryc
I try to run gpuinfo.sh to get gpu infomation, but run gpuinfo.sh show
---- Running < gpuinfo.sh > test ----
gpuinfo.sh not supported on current soc
2,200件の閲覧回数
Dhruvit
Hi @jerryc,
Please accept my apology for the inconvenience caused.
Please use the latest version of gpuinfo as below.
https://github.com/nxp-imx/imx-test/blob/lf-6.1.1_1.0.0/test/gpu/gpuinfo.sh
Here, SoC limitation is removed from gpu and gpuinfo tool
Thanks & Regards,
Dhruvit Vasavada
4 返答(返信)
2,213件の閲覧回数
Dhruvit
Hi @jerryc,
I hope you are doing well.
This seems to be due to using an old version of gpuinfo.sh
Please refer to below-mentioned script and commands.
imx-test/test/gpu/gpuinfo.sh
One can also use gputop utility.
Thanks & Regards,
Dhruvit Vasavada
2,208件の閲覧回数
jerryc
Hi @Dhruvit
imx-test/test/gpu/gpuinfo.sh not support i.MX8MP,why??
i.MX8MP:i.MX 8M Plus
2,201件の閲覧回数
Dhruvit
Hi @jerryc,
Thanks & Regards,
Dhruvit Vasavada
2,042件の閲覧回数
ravicalm
I am getting this error while running the gpuinfo.sh on imx7ulp board could you please reply
./gpuinfo.sh: line 4: /unit_tests/test-utils.sh: No such file or directory
./gpuinfo.sh: line 6: print_name: command not found
./gpuinfo.sh: line 10: platform: command not found
