How can I determine a specified ESAI slot to tri-state a transmiter data pins
已解决
跳至解决方案
1,301 次查看
javenlee
I use three transmiter(RX0/TX0 RX1/TX1 RX2/TX2) of IMX6Q ESAI. and I want to determine a specified slot of transmiter #0 to tri-state by clear "Transmit Slot Mask Register" bit. but the specified slot of transmiter #0 #1 #2 also be set to tri-state. How can I determine a specified slot to tri-state just in transmiter #0 ?
1 解答
1,193 次查看
Hi javen
unfortunately ESAI block has not possibilty
set to tri-state specified slot of only one transmiter.
chip
在原帖中查看解决方案
1 回复
1,194 次查看
Hi javen
chip
