How can I connect lpddr2 ram to i.MX 6DualLite
1,648 次查看
bijumohankc
The datasheet of the LPDDR2 RAM from Micron is attached below. I need the connection diagram between this ram and i.MX 6dl.
1 回复
1,411 次查看
Rita_Wang
You can refer to
i.Mx6DQSDL LPDDR2 Script Aid
Freescale i.MX6 DRAM Port Application Guide-DDR3
MX_Design_Validation_Guide
HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL
i.MX6DL LPDDR2 Support for L3.0.35_4.0.0
Rita
