How can I connect dual RGB display on i.MX6Solo ?
jackylam8
I only can source single RGB display connection diagram, using IOMUX is called "lcd"
I need to connect second RGB display interface to TV out, I found there is in IOMUX "ipu" can set the DISP1 data
but how about clock , hsync,v sync,,,etc.?
and could them can work in the same time ?
THANKS
Labels (4)
