I am using I.MX8QM board, and I want to configure PCI0 as Root complex and PCI1 as agent. How can I configure PCI0 as root complex and PCI1 as end point.
To work one of the PCI as an endpoint in IMX8QM kindly apply the following changes.
One can use the mx8qm-mek-pcie-ep.dts. In the imx8qm-mek-pcie-ep.dts, change the status to "okay" in the &pciea_ep node. It will configure pci0 as the endpoint.
