we have enabled hibernation in imx6q using following procedure:
a. enabled CONFIG_HIBERNATION in kernel menuconfig.
b. created swap file in /dev/mmcblk0p3 (in home directory):
dd if=/dev/zero of=swapfile bs=4k count=500000
mkswap swapfile
swapon swapfile
c. Added kerel arguments in u-boot (to resume from disk)
Hi Chetan
supported low power modes can be found in official nxp linux documentation,
in particular Table 10. Power Management Modes i.MX Linux Reference Manual
Unfortunately hibernation mode is not supported, sorry.
Hi Igor,
Thanks for the reply.
But in one of IMX6 board we are able to perform hibernation with same procedure.
In custom board(imx6q based) we are facing this issue.
Hi Chetankumar
one can try to debug it using AN4553 Using Open Source Debugging Tools for
Linux on i.MX Processors, comparing behaviour for both boards
Using Open Source Debugging Tools for Linux on i.MX Processors
