I am working on to implement hibernation (Suspend to disc) on an IMX6Q (SABRE AI EVK) with a 3.0.35 kernel,
I had gone through many patches and links in the web, but couldn't get any right thread to follow.
Can anyone suggest the best way to go ? Any help would be appreciated.
shyamjith
Solved! Go to Solution.
Hi shyamjith
hibernation is not supported on IMX6 linux, there are some example
for other processors, one can try to port them
http://www.gossamer-threads.com/lists/linux/kernel/1882614
http://elinux.org/images/0/0c/Slides.pdf
Hi shyamjith
Hi igor,
That was really helpful,Thank you very much for your time.
shyamjith
