Hi @danielberhe ,
Share your modified .cfx to me, when I have time, I will test it on my side.
BTW, you can modify your on board EVK debugger to the JLINK, then try the RT-UFL, whether that method works or not?
You can firmware the on board debugger to JLINK with the LPCScrypt:
https://www.nxp.com/lpcscrypt
Please try it on your side, the RT-UFL, you can use my doc mentioned file.
Kerry
