Hi, I am using nxp imx8m nano board and tried to play the .wav files and plugged my headphone 3.5mm jack with line out jack in nano board.but unable to hear any sounds.we need to do any settings for enabling the audio jack? Please help me to find a way
this is my #aplay -l output:
**** List of PLAYBACK Hardware Devices ****
card 0: btscoaudio [bt-sco-audio], device 0: 30020000.sai-bt-sco-pcm-wb bt-sco-pcm-wb-0 [30020000.sai-bt-sco-pcm-wb bt-sco-pcm-wb-0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: imxspdif [imx-spdif], device 0: S/PDIF PCM snd-soc-dummy-dai-0 [S/PDIF PCM snd-soc-dummy-dai-0]
Subdevices: 1/1
card 2: wm8524audio [wm8524-audio], device 0: HiFi wm8524-hifi-0 [HiFi wm8524-hifi-0]
Subdevices: 1/1
card 2: wm8524audio [wm8524-audio], device 1: HiFi-ASRC-FE (*) []
Subdevices: 1/1
Hello @Mohan51
You can try something like this (I tried with imx8mm EVK, but it should works for imx8mn too):
root@imx8mmevk:~# aplay -Dplughw:1,0 file_example_WAV_1MG.wav
Playing WAVE 'file_example_WAV_1MG.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
This is my aplay -l output:
root@imx8mmevk:~# aplay -l
Subdevices: 1/1
card 1: wm8524audio [wm8524-audio], device 0: 30030000.sai-wm8524-hifi wm8524-hifi-0 [30030000.sai-wm8524-hifi wm8524-hifi-0]
Subdevices: 1/1
card 3: imxspdif [imx-spdif], device 0: S/PDIF PCM snd-soc-dummy-dai-0 [S/PDIF PCM snd-soc-dummy-dai-0]
Subdevices: 1/1
And the tested BSP:
root@imx8mmevk:~# uname -a
Linux imx8mmevk 5.15.71+g50912be38601 #1 SMP PREEMPT Tue Sep 12 22:17:59 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux
In your case, you can try to use:
aplay -Dplughw:2,0 "your wav file"
Best regards.
Salas.
