Hi Community,
I have a question about i.MX6DQ ERR006282.
Please see Table 2 (page.9) of i.MX6DQ errata sheet (IMX6DQCE Rev.3).
It says "A ROM code fix for this issue is planned".
On the other hand, in ERR006282 "Proposed Solution" (page.181), it says "Fixed in silicon revision 1.3".
Then, I understand ROM code fix plan has been implemented in silicon revision 1.3 and the information of Table 2 is old.
Is this right?
Satoshi Shimoda
Solved! Go to Solution.
Hi, Satoshi
As far as I know, this issue has been fixed in silicon 1.3.
Hi, Satoshi
Hi Yongcai Huang,
Would you let me know what revision chip is fixed ERR006282 again?
I believe rev 1.3 is fixed, then how about rev 1.2 chip?
Actually, errata sheet (IMX6DQCE) rev.2 says "Fixed in silicon revision 1.2.2.", rev.3 says "Fixed in silicon revision 1.3", and rev.4 says "Fixed in silicon revision 1.2.".
So I'm confused.
Satoshi Shimoda
