HS400 strobe DLL status REF not lock! on eMMC
3,870 次查看
benjaminblanton
Hi,  I just received a new spin of boards with the latest D revision the IMX7D and have am having an issue with several boards.  In the past we always saw this set of warning pop up:
sdhci-esdhc-imx 30b60000.usdhc: warning! HS400 strobe DLL status REF not lock!
sdhci-esdhc-imx 30b60000.usdhc: warning! HS400 strobe DLL status SLV not lock!
but now we see this multiple times with IO errors and our linux image will not boot from Flash.  It doesnt happen always, maybe 50% of the time.
Can anyone help with this?
print_req_error: I/O error, dev mmcblk1, sector 0 flags 0
3,254 次查看
benjaminblanton
Hi Igor,
It looks like there is a kernal update related to a delay on the data strobe that fixes this issue.
https://git.kernel.org/pub/scm/linux/kernel/git/next/linux-next.git/commit/?h=next-20191009&id=2eaf5...
3,254 次查看
Hi Benjamin
reason may be additional board noise on some boards, one can try to
tweak emmc drive strength using DSE field iomux pad register, like IOMUXC_SW_PAD_CTL_PAD_SD3_DATA1.
Also may be useful to check board power supplies for noise, pay attention to ripple requirement
described in Hardware Development Guide for i.MX7Dual and 7Solo Applications Processors
