Iam using imx8m plus
hdmi is not providing 1920*1080 sometimes and provides 800*600
what could be done in order to resolve the issue
this is the logs observed in 2 monitors
The problem is caused by incorrect boot mode jumper setting. Please check it. did you connect hdmi cable correct? did you test it on the imx8mp EVK board? is it succesful?
yeah , its working fine with EVK
what is the solution that can be implemented in this since im new to yocto .
