HDMI display not working in i.MX 8M Quad EVM
4,122 次查看
gopinathsriniva
Hello Everyone,
I brought the i.MX 8M EVM and boot the default Android image flashed in the eMMC. It looks Android OS is booted successfully but the I cannot see the HDMI output in my 1080P HDMI monitor. But as per the Quick start guide, Android logo will appear on the HDMI display by default. Can anyone help me on this issue?
Below is the other information for your reference.
Version details:
u-boot
U-Boot SPL 2017.03 (Jan 24 2018 - 01:18:13)
Kernel
Linux version 4.9.68 (bamboo@shlinux23)
ASOP
ro.build.id=1.3.0-prc-rc2
ro.build.display.id=evk_8mq-userdebug 8.0.0 1.3.0-prc-rc2 20180110 dev-keys
ro.build.version.incremental=20180110
ro.build.version.sdk=26
ro.build.version.preview_sdk=0
ro.build.version.codename=REL
ro.build.version.all_codenames=REL
ro.build.version.release=8.0.0
I am getting below dmesg output continuously.
[ 1458.233876] [drm] HDMI/DP Cable Plug In
[ 1469.221881] [drm] HDMI/DP Cable Plug In
[ 1480.209875] [drm] HDMI/DP Cable Plug In
[ 1491.197879] [drm] HDMI/DP Cable Plug In
[ 1502.181873] [drm] HDMI/DP Cable Plug In
[ 1513.169879] [drm] HDMI/DP Cable Plug In
[ 1524.157871] [drm] HDMI/DP Cable Plug In
[ 1535.141872] [drm] HDMI/DP Cable Plug In
[ 1546.129883] [drm] HDMI/DP Cable Plug In
[ 1557.117876] [drm] HDMI/DP Cable Plug In
[ 1568.101933] [drm] HDMI/DP Cable Plug In
[ 1579.089871] [drm] HDMI/DP Cable Plug In
By the way, I tried the suggestions from previous related threads. Unfortunately no success.
Your suggestions are greatly appreciated. Thank You.
Gopinath S
标记 (1)
6 回复数
2,812 次查看
wang_david-yb
How to change the HDMI output resolution to 2160p
2,814 次查看
zbigniewmazur
NXP has a lot of bugs in their BSP. I have started already some nonstandard hdmi displays on IMX8mq evaluation kit. I can run your HDMI screen for your company.
Contact me on priv for pricing.
2,814 次查看
lingguan
Hi, I have the same problem. How to solve this?
2,814 次查看
gopinathsriniva
Can you check with different 1080P monitor. It seems there are some issues with few monitors. I got it working with 1080P Dell monitor.
2,814 次查看
Hi Gopinath
please try Demo Image:
Demo Images – i.MX 8MQuad EVK
https://www.nxp.com/webapp/Download?colCode=O8.1.0_1.3.0_ANDROID_DEMO_8MQ_GA&appType=license&locatio...
for programming use Manufacturing Toolkit and VivanteVTK for Android O8.1.0_1.3.0 8MQ GA
https://www.nxp.com/webapp/Download?colCode=O8.1.0_1.3.0_ANDROID_TOOL_8MQ_GA&appType=license&locatio...
May be recommended to try Linux and documentation from link
i.MX Software|NXP
"Getting Started" tutorial on
i.MX 8M Evaluation Kit|NXP
According to it: "Note that the HDMI output resolution is 1080P ", so check
that used hdmi supports that resolution.
Other videos
Getting Started with the i.MX 8M Evaluation Kit|NXP
Dual Displays with i.MX 8M Evaluation Kit|NXP
2,814 次查看
Danube
Hi igorpadykov
We saw Android P9 can fixed more 1080p monitor can't work issue. (Base on i.MX8M EVK and the same 1080p monitor)
Do you know and patch code for Android O8 ?
