Hi all!
I try to stream h264.
i.MX:
gst-launch -v v4l2src device=/dev/video1 ! 'video/x-raw-yuv,width=640,height=480,framerate=30/1' ! ffmpegcolorspace ! vpuenc codec=6 ! rtph264pay ! tcpserversink host=192.168.0.2 port=500
PC:
gst-launch-1.0 -v tcpclientsrc host=192.168.0.2 port=500 ! gdpdepay ! rtph264depay ! avdec_h264 ! videoconvert ! autovideosink sync=false
Got error:
Pipeline is PREROLLING ...
ERROR: from element /GstPipeline:pipeline0/GstGDPDepay:gdpdepay0: Could not decode stream.
Additional debug info:
gstgdpdepay.c(396): gst_gdp_depay_chain (): /GstPipeline:pipeline0/GstGDPDepay:gdpdepay0:
GDP packet header does not validate
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
Freeing pipeline ...
Any suggestion please?
Thanks!
I captured video to file and it play by gplay.
But VLC could play it.
Video recorded by command:
gst-launch v4l2src device=/dev/video1 num-buffers=1000 ! 'video/x-raw-yuv,width=640,height=480,framerate=30/1' ! ffmpegcolorspace ! vpuenc codec=6 ! mp4mux ! filesink location=/home/root/h264.mp4
VLC error:
[0x7f3320007b78] main demux debug: looking for demux module matching "mp4": 63 candidates
[0x7f3320c0e878] mp4 stream debug: found an empty box (null size)
[0x7f3320c0e878] mp4 stream debug: dumping root Box "root"
[0x7f3320c0e878] mp4 stream debug: | + ftyp size 32
[0x7f3320c0e878] mp4 stream debug: | + free size 8
[0x7f3320c0e878] mp4 stream debug: | + mdat size 2905871
[0x7f3320007b78] mp4 demux debug: unrecognized major file specification (mp42).
[0x7f3320007b78] mp4 demux error: MP4 plugin discarded (no moov,foov,moof box)
[0x7f3320007b78] ts demux debug: TS module discarded (lost sync)
[0x7f3320007b78] mod demux debug: MOD validation failed (ext=mp4)
It is needed to wrap the coded data of the i.MX6 VPU to a proper (say, MP4) file format.
Yuri
Yuri, it is not clear for me. I thought that mp4mux should be enough for wrap coded data. What I should add to pipeline?
You may try adding a parser before mp4mux : h264parse ! mp4mux
~Yuri.
