I am presently working on i.MX7D Sabre, I have booted marshmallow 6.0.1 on the board, I am trying to use Google app, when the board is online the voice recognition feature works but immediately after few seconds the app shuts down unexpectedly. Even when something is searched by typing in the search bar behavior remains same.
The google app doesn't respond when the board is offline even upon installing necessary offline packages.
Please find the attached log file which is taken when board was online and something was searched using voice commands.
Could anyone please suggest me for a possible workaround for the issue.
Thanks and Regards,
Supreeth
Original Attachment has been moved to: Google_App_voice_serach_log.txt.zip
Solved! Go to Solution.
Hello Supreeth,
The issue is not related to i.mx7d hardware and android version. Eeven on some mobile platform, the samilar issue also happens. you can try to install google app through google installer. So at first you should install google installer on i.mx7d board.
Hope my advice can help you!
Have a nice day!
TIC Weidong Sun
Hello Supreeth,
Have a nice day!
TIC Weidong Sun
