Getting started with i.MX 8M Nano
1,866 次查看
dibyajyoti
I am planning to use the new 8M Nano module in my design for a smart meter product. What would be the best place to start development?
标签 (2)
标记 (1)
6 回复数
1,681 次查看
dibyajyoti
Thank you very much for your continued support.
1,681 次查看
dibyajyoti
Thank you very much for the links diegoadrian and romitchatterjee Thank You ‌!
Can you point me to some links where I can buy the evk?
Thanks.
1,681 次查看
diegoadrian
You can find more information on the following web-page. Just go under the buy option part.
i.MX 8M Nano Evaluation Kit | NXP
Hope this information could be useful to you.
Diego.
1,681 次查看
romitchatterjee
You should get started by getting an evk first (i.MX 8M Nano Evaluation Kit | NXP ). You can find the getting started guide here: i.MX 8M Nano EVK Board Getting Started Guide | NXP .
1,681 次查看
diegoadrian
If you are willing to use the i.MX8MN. I suggest you use our Linux BSP. You could find more information on the following web-page.
One can find most of the information under the supporting information part.
Furthermore, you can start using our SDK to implement the M4 cortex in all the real-time processing applications that your product needs. You can find them in the following web-page:
You just need to select the desired board and the packages that you want to add.
Hope this information can be useful to you.
Diego.
