Hi everyone,
I'm using kernel 3.14.28 and gstreamer1.0-plugins-imx_0.12.1 to play video, and I'm looping it using the about-to-finish signal of playbin. When my application receives the signal, it sets the URI for playbin to the same file and the video loops seamlessly.
However, I'm getting a memory leak. The application slowly uses more and more memory until the oom killer closes it. Valgrind says memory is definitely lost but doesn't trace back further than g_malloc.
I've attached a copy of the test program here. Any help is greatly appreciated!
Marlon
Original Attachment has been moved to: gsttest.cpp.zip
Original Attachment has been moved to: Makefile.zip
Original Attachment has been moved to: gsttest.h.zip
解決済! 解決策の投稿を見る。
Hi Marlon
gstreamer-imx plugins developed and supported by community, one
could post it on meta-fsl-arm mailing list
https://lists.yoctoproject.org/listinfo/meta-freescale
trac.gateworks.com/wiki/Yocto/gstreamer
Alternatively one can try nxp gstreamer plugins described in
documentation package (Linux Guide, Release Notes) on
Hi Marlon
Thanks for the reply Igor.
I'm curious, why are there two different sets of gstreamer plugins? Is there any advantage to one version over the other?
Marlon
