GPU profiling in imx6q-sabresd
1,346 次查看
rakesh3
Contributor V
Hi team,
I am using the imx6qsabresd board and running the qt6 application. I want to enable the GPU profiling the board to test the qt6 GUI application. I did the following to enable that.
Enable the profiling at the galcore driver in the kernel at: drivers/mxc/gpu-viv/config
+USE_POWER_MANAGEMENT                = 0
+USE_PROFILER                        = 1
and added below to my bootargs
galcore.gpuProfiler=1
 But unfortunately, i am not getting the below file (gpuProfiler).
cat /sys/module/galcore/parameters/gpuProfiler
Please help me to get this profiling work in the imx6qsabresd board with BSP 5.10 and imx-gpu version 6.4.3
Rk
标签 (3)
标记 (1)
1,332 次查看
Bio_TICFSL
We detect some discrepancies between gpuprofiler and Qt6 however if you remove Qt6 it works, you may try a previous version of the BSP like 5.4 kernel to do gpuprofiler but with Qt5.
1,315 次查看
rakesh3
Contributor V
So you mean if I only use the Qt5 application then will the below interface file will be created?
 $cat /sys/module/galcore/parameters/gpuProfiler
because this is what i am missing now, i already have include the galcore.gpuProfiler=1 flag in the uboot.
Rk
