GPSD baudrate setting in gpsd file
BrintoJames
I just wanted to set baud rate of my GNSS port to 38400 in gpsd file if anyone knows please help me.
Below is the current content of the gpsd file content
START_DAEON="true"
GPSD_OPTIONS=""
DEVICES="/dev/ttyLP3"
USBAUTO="true"
GPSD_SOCKET="/var/run/gpsd.socket"
Brinto
Zhiming_Liu
You can choose udev rule or systemd service to set baud rate before gpsd service.
Here is the udev rule:
ACTION=="add", SUBSYSTEM=="tty", KERNEL=="ttyLP3", RUN+="/bin/stty -F /dev/%k 38400"
Add rule:
udevadm control --reload
udevadm trigger --action=add --subsystem-match=tty
This should be called when ttyLP3 is detected in system.
Zhiming
Zhiming_Liu
Please try to add  GPSD_OPTIONS="-b -s 4800"
Zhiming
BrintoJames
Got error like
Error connecting to gpsd: [Errno 104] Connection reset by peer
Brinto
Zhiming_Liu
Did you try to set 38400 baudrate and then get the log from system?
Referring the guidem,  you can get the log from syslog
LOGGING
When gpsd is running as a daemon (not in the foreground) is sends all of its logging to syslog(3). Logging is sent with ident "gpsd" using facility "LOG_USER".
If you are using syslog-ng, then you can send all gpsd logs to a file /var/log/gpsd. Put this at the end of your /etc/syslog-ng/syslog-ng.conf file:
destination gpsdf { file("/var/log/gpsd"); };
filter f_gpsd { program("gpsd"); };
log { source(src); filter(f_gpsd); destination(gpsdf); };
Zhiming
BrintoJames
I checked my system logs and confirmed that gpsd is running
and I can receive GNSS data correctly.
However, gpsd does not seem to set the baud rate to 38400 automatically. I have to manually configure it using:
stty -F /dev/ttyLP3 38400
Only after running this command does gpsd work as expected. But after a board reboot, the baud rate resets to 9600, and I have to set it again manually.
Is there a way to make gpsdalways use 38400 baud on startup? Let me know if you have any suggestions.
Brinto
Zhiming_Liu
Add rule:
Zhiming
%3CLINGO-SUB%20id%3D%22lingo-sub-2052539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGPSD%20baudrate%20setting%20in%20gpsd%20file%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20just%20wanted%20to%20set%20baud%20rate%20of%20my%20GNSS%20port%20to%2038400%20in%20gpsd%20file%20if%20anyone%20knows%20please%20help%20me.%3C%2FP%3E%3CP%3EBelow%20is%20the%20current%20content%20of%20the%20gpsd%20file%20content%3C%2FP%3E%3CP%3ESTART_DAEON%3D%22true%22%3C%2FP%3E%3CP%3EGPSD_OPTIONS%3D%22%22%3C%2FP%3E%3CP%3EDEVICES%3D%22%2Fdev%2FttyLP3%22%3C%2FP%3E%3CP%3EUSBAUTO%3D%22true%22%3C%2FP%3E%3CP%3EGPSD_SOCKET%3D%22%2Fvar%2Frun%2Fgpsd.socket%22%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3EBrinto%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2061791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20GPSD%20baudrate%20setting%20in%20gpsd%20file%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2061791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3CBR%20%2F%3E%3CBR%20%2F%3EYou%20can%20choose%20udev%20rule%20or%20systemd%20service%20to%20set%26nbsp%3B%3CSPAN%3Ebaud%20rate%26nbsp%3Bbefore%20gpsd%20service.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EHere%20is%20the%20udev%20rule%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%3E%3CSPAN%20class%3D%22token%20assign-left%20variable%22%3EACTION%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20operator%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20string%22%3E%22add%22%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22token%20assign-left%20variable%22%3ESUBSYSTEM%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20operator%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20string%22%3E%22tty%22%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22token%20assign-left%20variable%22%3EKERNEL%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20operator%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20string%22%3E%22ttyLP3%22%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22token%20assign-left%20variable%22%3ERUN%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20operator%22%3E%2B%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20string%22%3E%22%2Fbin%2Fstty%20-F%20%2Fdev%2F%25k%2038400%22%3C%2FSPAN%3E%3C%2FPRE%3E%0A%3CP%3EAdd%20rule%3A%3C%2FP%3E%0A%3CPRE%3Eudevadm%20control%20%3CSPAN%20class%3D%22token%20parameter%20variable%22%3E--reload%3CBR%20%2F%3E%3C%2FSPAN%3Eudevadm%20trigger%20%3CSPAN%20class%3D%22token%20parameter%20variable%22%3E--action%3C%2FSPAN%3E%3CSPAN%20class%3D%22token%20operator%22%3E%3D%3C%2FSPAN%3Eadd%20--subsystem-match%3CSPAN%20class%3D%22token%20operator%22%3E%3D%3C%2FSPAN%3Etty%3C%2FPRE%3E%0A%3CP%3EThis%20should%20be%20called%20when%20ttyLP3%20is%20detected%20in%20system.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2060214%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20GPSD%20baudrate%20setting%20in%20gpsd%20file%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2060214%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EI%20checked%20my%20system%20logs%20and%20confirmed%20that%20gpsd%20is%20running%3CBR%20%2F%3E%3CBR%20%2F%3Eand%20I%20can%20receive%20GNSS%20data%20correctly.%3CBR%20%2F%3E%3CBR%20%2F%3EHowever%2C%20gpsd%20does%20not%20seem%20to%20set%20the%20baud%20rate%20to%2038400%20automatically.%20I%20have%20to%20manually%20configure%20it%20using%3A%3CBR%20%2F%3E%3CBR%20%2F%3Estty%20-F%20%2Fdev%2FttyLP3%2038400%3CBR%20%2F%3E%3CBR%20%2F%3EOnly%20after%20running%20this%20command%20does%20gpsd%20work%20as%20expected.%20But%20after%20a%20board%20reboot%2C%20the%20baud%20rate%20resets%20to%209600%2C%20and%20I%20have%20to%20set%20it%20again%20manually.%3CBR%20%2F%3E%3CBR%20%2F%3EIs%20there%20a%20way%20to%20make%20gpsdalways%20use%2038400%20baud%20on%20startup%3F%20Let%20me%20know%20if%20you%20have%20any%20suggestions.%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20regards%2C%3CBR%20%2F%3EBrinto%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2060050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20GPSD%20baudrate%20setting%20in%20gpsd%20file%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2060050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EDid%20you%20try%20to%20set%2038400%26nbsp%3Bbaudrate%20and%20then%20get%20the%20log%20from%20system%3F%3C%2FP%3E%0A%3CP%3EReferring%20the%20guidem%2C%26nbsp%3B%20you%20can%20get%20the%20log%20from%26nbsp%3B%3CSTRONG%3Esyslog%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH2%20id%3D%22_logging%22%20id%3D%22toc-hId--552050573%22%20id%3D%22toc-hId--497353452%22%3E%3CA%20class%3D%22link%22%20href%3D%22https%3A%2F%2Fgpsd.gitlab.io%2Fgpsd%2Fgpsd.html%23_logging%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ELOGGING%3C%2FA%3E%3C%2FH2%3E%0A%3CDIV%20class%3D%22sectionbody%22%3E%0A%3CDIV%20class%3D%22paragraph%22%3E%0A%3CP%3EWhen%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3Egpsd%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eis%20running%20as%20a%20daemon%20(not%20in%20the%20foreground)%20is%20sends%20all%20of%20its%20logging%20to%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3Esyslog%3C%2FSTRONG%3E(3).%20Logging%20is%20sent%20with%20ident%20%22gpsd%22%20using%20facility%20%22LOG_USER%22.%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22paragraph%22%3E%0A%3CP%3EIf%20you%20are%20using%20syslog-ng%2C%20then%20you%20can%20send%20all%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3Egpsd%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Elogs%20to%20a%20file%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%2Fvar%2Flog%2Fgpsd%3C%2FSTRONG%3E.%20Put%20this%20at%20the%20end%20of%20your%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%2Fetc%2Fsyslog-ng%2Fsyslog-ng.conf%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Efile%3A%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22listingblock%22%3E%0A%3CDIV%20class%3D%22content%22%3E%0A%3CPRE%3Edestination%20gpsdf%20%7B%20file(%22%2Fvar%2Flog%2Fgpsd%22)%3B%20%7D%3B%0Afilter%20f_gpsd%20%7B%20program(%22gpsd%22)%3B%20%7D%3B%0Alog%20%7B%20source(src)%3B%20filter(f_gpsd)%3B%20destination(gpsdf)%3B%20%7D%3B%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2058511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20GPSD%20baudrate%20setting%20in%20gpsd%20file%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2058511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGot%20error%20like%3C%2FP%3E%3CP%3EError%20connecting%20to%20gpsd%3A%20%5BErrno%20104%5D%20Connection%20reset%20by%20peer%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3EBrinto%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2056604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20GPSD%20baudrate%20setting%20in%20gpsd%20file%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EPlease%20try%20to%20add%20%26nbsp%3B%3CEM%20class%3D%22t55VCb%22%3EGPSD_OPTIONS%3D%22-b%20-s%204800%3C%2FEM%3E%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E
