GPMI driver for i.mx6sl
yanvasilij
Hello!
I am trying to run QNX6.5 etfs driver for parallel NAND memory on my i.MX6SL based board. I ported BSP for Freescale i.MX6Q Sabre Lite Board (http://community.qnx.com/sf/wiki/do/viewPage/projects.bsp/wiki/FreescaleImx6QSabreLite) and it successfully started on my board. After that I took driver from BSP for NXP MCIMX7 Sabre Board (http://community.qnx.com/sf/wiki/do/viewPage/projects.bsp/wiki/NxpMcimx7sabre) and ported it for my platform. I added driver initialization in  QNX startup (added “fs-etfs-imx-micron –e” to .script section in build-file). So drivers stops execution while initialization gpmi module on waiting IMX_APBH_IRQ interrupt (45 - Logical OR of APBH DMA channels 0-3 completion and error interrupts). What am I doing wrong?
So gpmi initialization sequence is follows.
1) Clock enable in DCD section:
DCD_ENTRY(1, 0x020c4068, 0xffffffff)
DCD_ENTRY(2, 0x020c406c, 0xffffffff)
DCD_ENTRY(3, 0x020c4070, 0xffffffff)
DCD_ENTRY(4, 0x020c4074, 0xffffffff)
DCD_ENTRY(5, 0x020c4078, 0xffffffff)
DCD_ENTRY(6, 0x020c407c, 0xffffffff)
DCD_ENTRY(7, 0x020c4080, 0xffffffff)
2) Setup pin muxing in startup:
            out32(MX6X_CCM_BASE + MX6X_CCM_CCGR4, 0xFFFFF300 );
            pinmux_set_swmux(SWMUX_NANDF_CLE, MUX_CTL_MUX_MODE_ALT0);
            pinmux_set_padcfg(SWPAD_NANDF_CLE, PAD_CFG_0);
            pinmux_set_swmux(SWMUX_NANDF_ALE, MUX_CTL_MUX_MODE_ALT0);
            pinmux_set_padcfg(SWPAD_NANDF_ALE, PAD_CFG_0);
            pinmux_set_swmux(SWMUX_NANDF_WP_B, MUX_CTL_MUX_MODE_ALT0);
            pinmux_set_padcfg(SWPAD_NANDF_WP_B, PAD_CFG_0);
            pinmux_set_swmux(SWMUX_NANDF_RB0, MUX_CTL_MUX_MODE_ALT0);
            pinmux_set_padcfg(SWPAD_NANDF_RB0, PAD_CFG_1);
            pinmux_set_swmux(SWMUX_NANDF_CS0, MUX_CTL_MUX_MODE_ALT0);
            pinmux_set_padcfg(SWPAD_NANDF_CS0, PAD_CFG_0);
            pinmux_set_swmux(SWMUX_NANDF_CS1, MUX_CTL_MUX_MODE_ALT0);
            pinmux_set_padcfg(SWPAD_NANDF_CS1, PAD_CFG_0);
            pinmux_set_swmux(SWMUX_NANDF_CS2, MUX_CTL_MUX_MODE_ALT0);
            pinmux_set_padcfg(SWPAD_NANDF_CS2, PAD_CFG_0);
            pinmux_set_swmux(SWMUX_NANDF_CS3, MUX_CTL_MUX_MODE_ALT0);
            pinmux_set_padcfg(SWPAD_NANDF_CS3, PAD_CFG_0);
            pinmux_set_swmux(SWMUX_SD4_CMD, MUX_CTL_MUX_MODE_ALT1);
            pinmux_set_padcfg(SWPAD_SD4_CMD, PAD_CFG_0);
            pinmux_set_swmux(SWMUX_SD4_CLK, MUX_CTL_MUX_MODE_ALT1);
            pinmux_set_padcfg(SWPAD_SD4_CLK, PAD_CFG_0);
            pinmux_set_swmux(SWMUX_NANDF_D0, MUX_CTL_MUX_MODE_ALT0);
            pinmux_set_padcfg(SWPAD_NANDF_D0, PAD_CFG_0);
            pinmux_set_swmux(SWMUX_NANDF_D1, MUX_CTL_MUX_MODE_ALT0);
            pinmux_set_padcfg(SWPAD_NANDF_D1, PAD_CFG_0);
            pinmux_set_swmux(SWMUX_NANDF_D2, MUX_CTL_MUX_MODE_ALT0);
            pinmux_set_padcfg(SWPAD_NANDF_D2, PAD_CFG_0);
            pinmux_set_swmux(SWMUX_NANDF_D3, MUX_CTL_MUX_MODE_ALT0);
            pinmux_set_padcfg(SWPAD_NANDF_D3, PAD_CFG_0);
            pinmux_set_swmux(SWMUX_NANDF_D4, MUX_CTL_MUX_MODE_ALT0);
            pinmux_set_padcfg(SWPAD_NANDF_D4, PAD_CFG_0);
            pinmux_set_swmux(SWMUX_NANDF_D5, MUX_CTL_MUX_MODE_ALT0);
            pinmux_set_padcfg(SWPAD_NANDF_D5, PAD_CFG_0);
            pinmux_set_swmux(SWMUX_NANDF_D6, MUX_CTL_MUX_MODE_ALT0);
            pinmux_set_padcfg(SWPAD_NANDF_D6, PAD_CFG_0);
            pinmux_set_swmux(SWMUX_NANDF_D7, MUX_CTL_MUX_MODE_ALT0);
            pinmux_set_padcfg(SWPAD_NANDF_D7, PAD_CFG_0);
            pinmux_set_swmux(SWMUX_SD4_DAT0, MUX_CTL_MUX_MODE_ALT2);
            pinmux_set_padcfg(SWPAD_SD4_DAT0, PAD_CFG_2);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
3) GPMI initialization in driver. Briefly:
// APBH, BCH and GPMI init
if (nand_init(cio) != 0) {
        dev->log(_SLOG_CRITICAL, "nand_init failed : %s", strerror(errno));
        // We will not return
    cio->apbhirq = IMX_APBH_IRQ;
    cio->bchirq = IMX_BCH_IRQ;
    // Start-up a thread that is dedicated to interrupt processing
    cio->apbhirq_expected = 0;
    pthread_mutex_init(&cio->apbhmutex, NULL);
    pthread_cond_init(&cio->apbhcond, NULL);
    pthread_create(NULL, NULL, apbhint_thread, cio);
    cio->bchirq_expected = 0;
    pthread_mutex_init(&cio->bchmutex, NULL);
    pthread_cond_init(&cio->bchcond, NULL);
    pthread_create(NULL, NULL, bchint_thread, cio);
    if (nand_wait_busy(cio, MAX_RESET_USEC, 0) != 0) {
        dev->log(_SLOG_CRITICAL, "Timeout on RESET");
    // Create reset device and reset the part - for some devices it must be first command
    create_reset_descriptor(reset_ptr);
    status = run_dma((apbh_dma_t*)reset_ptr, cio, NAND_DMA_GPMI_TRANS, (uint32_t)virtual_to_physical_addr(reset_ptr));
    if (status != NAND_EOK) {
        dev->log(_SLOG_CRITICAL, "DMA operation fail");
    delay(2);
    // Create read status chain and read status register from device
    create_readStatus2_descriptor(read_status_ptr, mem_stat_ptr, 1);
                status = run_dma((apbh_dma_t*)read_status_ptr, cio, NAND_DMA_GPMI_TRANS, (uint32_t)virtual_to_physical_addr(read_status_ptr));     //<<<<<<<<<<<<<<<<< Stops here <<<<<<<<<<<<<<<<<<<
Vasily
Labels (2)
Hi Vasily
if you are trying to boot from nand one can try mfg tool
i.MX6 boot from Nand flash
or other procedures
i.MX7: Flashing Images to NAND - Develop.phytec - PHYTEC Wiki
yanvasilij
Hi Igor!
Actually I am trying to access to NAND from QNX OS. So I want to run NAND driver after booting.
Hi Vasily
qnx is not supported by nxp, may be helpful to look at baremetal gpmi
examples in sdk (check zip on below link)
https://community.nxp.com/thread/432859
