GPIO that enable Interrupt and write string on console
1,055 次查看
enaud
hi,
how modified mx53_loco.c for to obtain an interrupt from a GPIO(is a button) and when is enabled write a string on Console?
i have found this from the web:
static irqreturn_t button_interrupt(int irq, unsigned long data)
printk(KERN_INFO "Hello World\n");
tasklet_schedule(&my_tasklet);
return IRQ_HANDLED;
static int __init hello_start(void)
int ret;
printk(KERN_INFO "Loaded hello module....\n");
ret = request_irq(gpio_to_irq(163), button_interrupt,
   IRQF_DISABLED | IRQF_TRIGGER_FALLING,
   "hello", NULL);
if(ret){
  printk(KERN_ERR "Failed to request IRQ\n");
  return ret;
return 0;
I dont undstand this code:  tasklet_schedule(&my_tasklet);
GPIO is 6_3 with interrupt 105.
cat value -----> 0 when is pressed; 1 when isnt pressed.
Where i must put this code in my mx53_loco.c?
656 次查看
AlejandroSierra
Where are you defining the GPIO pin in you code? you should use DEFINE function called IMX_GPIO_NR(6, 3)
tasklet_schedule function means that you are starting a tasklet or "small thread" on the kernel to attend the ISR without blocking the whole system.
657 次查看
AlejandroSierra
