GLES Vivante GPU in i.MX6 doesn't support glMapBuffer
1,536件の閲覧回数
kimlim
I tried to make use of glMapBuffer in i.mx6 to create a read write buffer[1] but found that glMapBuffer is not implemented by the GLES of Vivante GPU.
Any way we could create a read write buffer to allow bi-directional GPU-Host communication?
[1] http://www.informit.com/articles/article.aspx?p=2033340&seqNum=2
タグ(2)
1,286件の閲覧回数
Bio_TICFSL
Hi Kim,
From the OpenGL ES2 and ES3 spec and its header file (http://www.khronos.org/registry/gles/api/3.0/gl3.h) and,
the glMapBuffer is not supported. Instead, the glMapBufferRange is supported.
