Freescale git out of commission.
892 次查看
le-cherng_yong
Hi there
I was maintaining an old project which use the imx6 yocto repo. I found that the old freescale git has be out of commission and replace with source.codeaurora and this impact one of the bb file in the
firmware-imx.inc\firmware-imx\recipes-bsp\meta-bsp\imx - meta-fsl-bsp-release - i.MX Yocto Project R...
which still pointing to the old freescale git. Can you help to update it to point to the new git source?
Yong
标记 (1)
846 次查看
gusarambula
Hello Yong,
My apologies for the inconveniences this is causing. As you pointed out the git://git.freescale.com repository was decommissioned, and its contents were moved to the following repositories:
github.com/NXP
github.com/NXPMicro
https://source.codeaurora.org/external/imx/
As for the imx-firmware packages in particular, the firmware-imx GIT repository new location is:
https://github.com/NXP/imx-firmware
I hope this helps!
