Frame rate support in I.MX8M MINI processor
1,009 次查看
viralvasa
We are using I.MX8M MINI processor's MIPI DSI Interface. We are using single lane to connect it to our display LCD. Video that needs to be displayed is of resolution 960x320 pixel ( we are using RGB 565/666 mode)
Datasheet mentions 1080p@60fps.
Can we achieve Frame rate of 120 fps with this resolution ?
997 次查看
Bio_TICFSL
Hello viralvasa,
If the current MIPI driver custom resolution or support that resolution with your driver, yes its possible to get 120fps.
regards
