For i.MX8M EVK board , how to Build Image to eMMC without using SD card?
1,369 次查看
jhpark_vine
For i.MX8M EVK board , how do Build  eMMC Images without using SD card?
Using the following bitbake command , it produced  SD card images.
bitbake -v core-image-minimal
to build  U-Boot eMMC in yocto build system
changed local.conf
$ echo "UBOOT_CONFIG = \"emmc\"" >>
conf/local.conf
but bitbake failed and did not produced eMMC images.
let me know how to Build Image to eMMC without using SD card ..
1,359 次查看
bernhardfink
1,360 次查看
bernhardfink
Seems that a solution for this problem can be found here:
https://community.nxp.com/t5/i-MX-Processors/IMX8M-error-building-uboot-for-emmc-with-Yocto/m-p/9113...
Bernhard.
1,348 次查看
jhpark_vine
Thanks. i produced eMMC images for i.MX8M EVK  following your guide.
