For USB 2.0 data differential pair (D+ D-), is 65 ohm single-ended impedance OK?
oway
Our PCB single-ended impedance of USB 2.0 data differential pair (D+ D-) is 65 ohms (and the differential impedance is 90 ohms).
Is this OK?
If not OK, what symptoms can we expect?
Rita_Wang
The differential impedance is 90 ohms. You can refer to our hardware design documents and refer to the reference board design.
