Flashing through UART
1,704件の閲覧回数
vishwas_br
Hi, I am trying to flash MIMXRT1064 through UART using MCUXpresso Secure Provisioning Tool. All the necessary configurations are done. The Boot mode is set to Serial Downloader(01). The processor is connected properly. We are getting the same errors repeatedly. Are there any other configurations or settings that need to be done? Kindly help
1,672件の閲覧回数
jingpan
Hi @vishwas_br ,
Is this your own board?
Are you sure the chip is power up correctly?
Did you set other boot config pins?
Can you debug the chip?
Jing
1,668件の閲覧回数
vishwas_br
Hi, @jingpan
Thank you for getting back. The problem is resolved. The boot config pins are set correctly and it is working properly.
